Re: Hey Vet...544 Hiccup!
Posted by Allan In NE on March 24, 2006 at 13:12:52 from (148.78.243.26):
In Reply to: Hey Vet...544 Hiccup! posted by BillyinStoughton on March 24, 2006 at 12:00:03:
Boy,
I sure don't want to counter the Vet and all, but I disagree. If that carburetor has been removed, you have to totally resynchronize the governor with the carburetor or sometimes the darned thing will flare.
First you make all the linkage adjustments per the manual as well as the low and high-speed adjustments. After that, adjust those carburetor enrichment settings.
If it is still "hunting" it needs the spring tension on the governor tightened just to the point where the hunting stops and no more.
Then at that point, you might have to re-enrich the low or high side just a touch until it "cracks" throttle right. If you cannot get it to stop that hesitation, recheck your dwell and timing because it is too slow.
Be glad to scan the procedure if you need it. And, to be sure, I'm just trying to help, not start a darned war.
Allan
third party image
