Re: M Transmission Input Shaft Seal
Posted by Haas on March 24, 2006 at 14:03:48 from (12.65.0.16):
In Reply to: M Transmission Input Shaft Seal posted by Wicksfield on March 24, 2006 at 05:53:47:
The input shaft and gear is mounted in a holder and the shaft is supported by two bearings. The seal is in a separate seal holder that bolts to the input shaft bearing holder assembly. The seal holder is held on with 4 bolts. The input shaft holder is bolted to the transmission housing with 6 or 8 bolts. If you just take off the seal holder, there is no way the input shaft can fall down. You will have some "fun" down under there. To get the seal holder out, you will have to disconnect the main drive shaft coupling. Be prepared to replace the rubber washers and the metal cup washers in the coupling, as they are likely bad. Getting the coupling off the transmission input shaft may be a chore. I don't know if it will come out without taking out the clutch shaft or not. The seal runs on the coupling, not directly on the shaft, so the coupling must come off before you can take off the seal holder. I've not done an M, but on a Super H, I had to use a puller to get the drive coupling off. I've seen some say that these will come off with a pry bar once the retainer bolt and washer are out, but I had no such luck. I had the input shaft bearing assembly out anyway, so using the puller was no big deal.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
