Re: IH 314? semi mount mechanical lift plow
Posted by Hugh MacKay again on March 24, 2006 at 16:02:12 from (209.226.106.182):
In Reply to: IH 314? semi mount mechanical lift plow posted by Mike S 806/H on March 24, 2006 at 11:07:32:
Mike: The parts book shows a photo of the 4 bottom 412 with mechanical lift, not great detail as the photo is from wrong side. It looks like telescope type rod back along top of plow with a hinged linkage to the pivot point of fast hitch.
Here are a list of the parts 1. arm lift, 2. clevi chain, 3. clevis w/chain, 4. pivot bell crank, 5. bellcrank transport rear wheel raising, 6. rod lift, 7. pipe lift, 8. grease fitting for lubricating bellcrank, 9. pipe chain stifener and 10. washer, chain indicator -2-.
It looks as though most of this is right at front of plow with items 6 and 7 going to rear wheel. I'd say one of these being a rod and solid, slides inside the pipe lift and telescopes within.
If you would like copies of this send me an e mail.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
