Re: H Carb rebuild
Posted by riverbend on March 26, 2006 at 06:51:47 from (208.160.33.196):
In Reply to: H Carb rebuild posted by djp on March 25, 2006 at 18:20:16:
Tisco has two levels of carb its, the basic (pn BXXX) and the complete (CXXX). The complete kit has throttle and choke shafts, and the choke plate.
Before I used the choke shaft from this kit, I would braze the lever to the shaft. They are just pressed together and with use, the lever can get loose on the shaft.
After that, try your IH dealer for individual parts. I could not get the spray tube from the dealer, but it was in the complete kit.
