Diesel problem on IH B275
Posted by BUCWEET on March 26, 2006 at 19:03:14 from (66.195.57.110):
I've got an IH B 275, diesel when started cold it hits on 3 cyl. and smokes. After 15-20 min. run time, it hits on all 4 and stops smoking. #3 cyl. is the bad cyl. I've swapped injectors from another cyl. set overnite, started cold and the same thing happens, after 15-20 min. it's running fine.
Not an injector problem.
Could it be: 1. Bad lifter 2. Siezed up valve rocker arm. 3. Bad rings. 4. Scored piston. Any suggestions????????????
