Re: Changing Ring Gear on Super C
Posted by Harold Hubbard on March 27, 2006 at 03:36:31 from (66.6.176.23):
In Reply to: Changing Ring Gear on Super C posted by CharleyFarmall on March 27, 2006 at 03:09:54:
The hardest part is splitting the tractor to get the flywheel off, and while you are at it you might as well change the clutch if it needs it. Once you get the flywheel off, set it clutch side down on a block of wood that is small enough for the gear to fit over. Most ring gears come off towards the clutch side, but check to be sure. If it looks like it comes off the other way, just turn the wheel over. Be sure the flywheel is solidly supported, you don't want to be chasing it around, or picking it off your toe half way through the job. Heat the gear with a torch, working evenly around it and occaisionally tapping with a small hammer until it loosens up and falls off. Turn the flywheel over and lay the new gear on it with something to hold it up. I usually lay a couple of welding rods across under it. You can also just heat it somewhere else, and pick it up and move it when it's ready. Heat the new gear carefully and evenly until it is just hot enought to melt a piece of solder laid on it, then pull out your supports and quickly tap the gear onto the flywheel. Make sure it seats tightly all the way around. I use a small hammer and a brass punch to do this.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
