Re: international 240 utility with hydraulic bucke
Posted by Nat 2 on March 27, 2006 at 09:12:16 from (64.80.108.52):
In Reply to: international 240 utility with hydraulic bucket posted by jagar on March 27, 2006 at 08:19:20:
Weight is approximately 2 tons.
There's more wrong than just timing if the distributor shaft isn't turning anymore. It might have twisted off in the distributor, if you're lucky. Anything else means you're going to have to tear the tractor down to access the cam shaft and timing gears.
