Re: international 240 utility with hydraulic bucke
Posted by Hugh MacKay on March 27, 2006 at 09:27:34 from (209.226.106.78):
In Reply to: international 240 utility with hydraulic bucket posted by jagar on March 27, 2006 at 08:19:20:
jagar: If you distributor is not turning, most likely it is a small gear and shaft within the drive housing onto which the distributor mounts. That distributor drive gear is very small compared to timing gears. These give trouble when not lubricated as per the manual.
It could be timing gears, however the best way to check is make sure the distributor shaft is not turning as the engine turns over. If that is so, then remove valve cover to see if valves are operating as they should every revolution of the engine. That will tell you where the problem is.
