Re: Sleeves on a Super C
Posted by El Toro on March 27, 2006 at 11:22:57 from (152.163.100.65):
In Reply to: Sleeves on a Super C posted by trw on March 27, 2006 at 10:55:14:
You should use dish deterrgent on the bottom edges of the sleeves. You need to have the block area free of all rust, scale or dirt where those seals are installed for the sleeves. The sleeves are not pressed into the block like the H and the M's. The area at the top of the block
where the top of the sleeve sits needs to be cleaned of any rust or dirt too. You should be able to push the sleeves into place by hand. You may need to make a holddown using a piece of flatstock metal to keep these sleeves from moving
when installing the pistons. The pistons will probably need more effort to install than the sleeves. Hal
