Re: Farmall cub loaders
Posted by Janicholson on March 27, 2006 at 14:00:24 from (199.17.6.175):
In Reply to: Farmall cub loaders posted by Farmer1957 on March 27, 2006 at 12:14:57:
Many are available, others may supply brands, etc.
They are very useful, but limited to light loads (in the neighborhood of 300#) rough travel, or higher loads will break the tractor at the: axle, front casting, engine casting, or torque tube.
Be warned. Seen the result of excess.
JimN
