Re: F-20 Fuel lines
Posted by El Toro on March 27, 2006 at 14:34:35 from (205.188.116.133):
In Reply to: F-20 Fuel lines posted by Jonathan Brown on March 27, 2006 at 13:52:54:
You only need a tube cutter and a double flaring tool. Buy the same size brake lines as your fuel lines and bend and flare them. Easier to
double flare if you have vise. Hal
