Re: Making Fast Hitch 3pt Conversion Prongs
Posted by r4etired on March 28, 2006 at 16:39:01 from (64.12.116.65):
In Reply to: Making Fast Hitch 3pt Conversion Prongs posted by Tweeter on March 28, 2006 at 14:54:33:
I have 4 farmalls with 2pt. Over the years I have bought several types of adapters,never found one I really liked. I now make my own. I take a standard 2pt draw bar, on the back where it turns down I weld a 7/8 by 6in long piece of steel,prior to welding it on, about an inch and a quarter from the end I cut a round bottom 7/8 slot about half way down,I then cut down a piece of quarter in tube steel so it will slide over the 7/8 by 6in piece. cut a matching slot in the slide piece so you have a lock down, Then I drill a hole in the top for a pin to lock it in place.If you weld it at the very top there is still room for the wagon tongue to go under it, I have 4 of these built, really handy just back under raise up and you are hooked,slide the lock sleeve in place pin it and go to work
