Re: Saved an H from the scrap man.. But it is stuc
Posted by Josh H on March 28, 2006 at 17:53:00 from (72.165.152.4):
In Reply to: Saved an H from the scrap man.. But it is stuck..? posted by Truck on March 28, 2006 at 17:27:06:
I would not pop the clutch. Soak it in some kind of penetrating oil, some use brake fluid or ATF. If it smoked before and now its stuck, I'd plan on a rebuild.
Josh H
