Re: Lift pump
Posted by Magman on March 28, 2006 at 18:26:08 from (152.163.100.65):
In Reply to: Lift pump posted by RSK on March 28, 2006 at 14:39:23:
I dont know what you have when you say the rubber
hydraulic fittings . The pump is a gear driven pump with round steel balls that hold the pressure.
How about the fitting that runs the pump from the tranny are both pins in it and hooked up right? The clutch deal is becuase it runs off the tranny and its always running when the clutch is out and when you push the clutch pedal down it disingages the pump. You may have a broken tooth on one of the gears inside I supose or there is a rubber mount in the clutch housing in the center of the drive shaft maybe thats ripped or bad also.
Just a few things I can think of to check
JON
