Re: IH 504 Value??
Posted by TomH in PA on April 09, 2009 at 16:38:48 from (72.171.0.139):
In Reply to: IH 504 Value?? posted by Jim in Ma. on April 09, 2009 at 12:07:30:
If it runs make sure the Torque Amp works (try a few starts and stops with the lever in both positions) and see how the power steering responds at lower RPM. If it doesn't run I'd assume it has something expensive wrong.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
