Re: C123 piston and head interferance!
Posted by Red Dave on March 29, 2006 at 16:23:32 from (66.109.236.189):
In Reply to: C123 piston and head interferance! posted by Jack in OH on March 29, 2006 at 15:32:26:
Jack, I ran into the same problem just last month. On my B, I did an overhaul, but I used a Clevite kit. 3-1/8 high dome pistons, so I ended up with 123 Cubic inches too. The pistons I took out were M&W Add Power's, also 3-1/8 high dome, but the shape of the dome was just a little bit different. When I put it together, I torqued the head and when I turned it over to set the valve lash, it stopped dead. The edge of the domes hit the step on the head in each combustion chamber. I talked it over with my local IH tractor guru and his opinion was that somebody probably planed the head sometime in the past. He said he had run into it before and his solution was to just grind out enough from each combustion chamber to clear the pistons. He reccomended that I NOT take any off the pistons because they are weight-matched and I had no way to re-weigh them accurately, so there was no way to be sure they were all the same weight. I had a machinist take a little off the head in each combustion chamber, then put the head back on without the gasket, and put a piece of masking tape on the spot that was hitting to make it easier to see what was hitting together. The head before machining. The pistons hit that right angle edge.
[URL=http://i16.photobucket.com/albums/b16/RedDave/CombustionChamber2.jpg][IMG]http://i16.photobucket.com/albums/b16/RedDave/th_CombustionChamber2.jpg[/IMG][/URL] The pistons. They hit just on the near edge about halfway up the raised part. [URL=http://i16.photobucket.com/albums/b16/RedDave/Piston3.jpg][IMG]http://i16.photobucket.com/albums/b16/RedDave/th_Piston3.jpg[/IMG][/URL] This is the head after the machinist took a little out with a milling machine and a slight adjustment with a die grinder. [URL=http://i16.photobucket.com/albums/b16/RedDave/HeadAfterMachining3.jpg][IMG]http://i16.photobucket.com/albums/b16/RedDave/th_HeadAfterMachining3.jpg[/IMG][/URL] After enough was out, I put it back together and it has been running just fine. I don't know if the pictures will show up or not.
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
