Re: IH 2444 DIESEL w/ LOADER PROBLEMS NEED HELP!!!
Posted by FromJB2 on March 29, 2006 at 19:13:51 from (72.56.121.128):
In Reply to: IH 2444 DIESEL w/ LOADER PROBLEMS NEED HELP!!!!!!! posted by JOEFLO on March 29, 2006 at 17:58:46:
Hi Joe, can't help you with the loader/hydraulic problems as I am only know the B414,434,444,384 agriculture models. They all use the same BD154 British built Diesel engine. This engine is a very reliable but hard to start in cold weather engine. Lasts a long time if properly maintained.
To start the engine requires the use of the glow plugs. I believe on that model the glow plugs are activated by pushing in and holding the start key. The bad thing about the glow plugs is they are wired in series so if one burns out they all stop working.
This engine has a high compression ratio 22:1 and normally rattles and clanks a little when cold and low idle. As for the white/blue smoke this should clear up once the engine warms up. If it dosen't then there are other problems like bad injectors, rings, or injection pump timing.
Good luck
JB2
