Re: 1066 Draft Lever
Posted by the tractor vet on March 30, 2006 at 07:03:34 from (66.202.111.45):
In Reply to: 1066 Draft Lever posted by Wicksfield on March 30, 2006 at 06:32:27:
Tighten the bolt in the control rod bearing support it is on the back side and is a 5/16th's bolt that goes thru , it may be rusted so becareful as it will break the best way is to remove it and clean the threads and add a dab of neverseeze then tighten it up just enough to add friction to hold the draft sencening lever in place but not enought that it will not move it is sorta of a feel setting .
