Re: Starter Occasionally Hangs Up
Posted by old on March 30, 2006 at 16:52:41 from (207.69.137.7):
In Reply to: Starter Occasionally Hangs Up posted by Dellbertt on March 30, 2006 at 16:42:39:
As Allan says and also you will need to dress up the ring gear. The longer you put it off the worse it will get and the more harm it does to both parts. Its your call but one of these days it may end up takeing out the ring gear and then you will need a new ring gear and bendex
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
