Re: 1000 to 540 pto
Posted by Jim J on March 30, 2006 at 19:35:13 from (65.222.50.173):
In Reply to: 1000 to 540 pto posted by jhorejsi on March 30, 2006 at 14:40:16:
The PTO center housing is the same as a Magnum. You can convert your PTO to a dual shaft PTO with a 806- 1086 PTO and a dual speed PTO rear cover off of a 5088 or a Magnum. You will need to use the Shafts and gears out of the donor PTO and the center section out of your PTO out of your 5288.
