Re: only runs with starter switch held down
Posted by Hermit on April 01, 2006 at 14:04:33 from (69.21.48.77):
In Reply to: only runs with starter switch held down posted by IH10020 on April 01, 2006 at 12:57:40:
If someone has installed a ballast resistor for whatever reason, that could cause a problem.
