Re: IH 140
Posted by Hugh MacKay on April 02, 2006 at 01:59:17 from (216.208.58.142):
In Reply to: IH 140 posted by BruceR TN on April 01, 2006 at 16:03:02:
Bruce: You didn't mention fire or spark, I assume you have that.
The carb could be several things; float setting wrong, air leak within carb or where it bolts to manifold. From your description, it sounds as though this tractor may have been parked for awhile. You may have old gas in carb that has turned to shelac. Shelac may not be blocking flow through carb to the drain, but it could have fuel - air mixture going to manifold blocked up.
