Re: Farmall 200 Drowning
Posted by Andrew Z on April 02, 2006 at 14:09:41 from (24.181.190.89):
In Reply to: Farmall 200 Drowning posted by Fencemender on April 02, 2006 at 13:31:42:
As for the H2O in the oil you might want to pull the oil pan and look around the sleeves and see if you can spot some rust up there. Leave the oil pan off for a while and see if yoiu can collect the dripping water on a piece of cardboard to locate the source. This would mean that you have a bad "O" ring on the sleeve.
Andrew
