Re: Hydraulic Reservoir SA
Posted by VAJerry on April 02, 2006 at 18:24:56 from (207.78.118.7):
In Reply to: Hydraulic Reservoir SA posted by Mark on April 02, 2006 at 17:17:49:
Just completed mine. GET THE KIT. Different sized O rings you will spend as much running for the parts and still will not have the gaskets. I took two and made one so I had plenty of parts around. When you pull the head there are passage ways for the fluid and different holes. I blew air in some of the holes to get the plungers out and they have O rings on them. Work in a clean area and be able to find fallen parts. I did mine outside in the middle of a 20x20 tarp. There are several springs inside but nothing that should go flying. Take it easy and use common sense and it is straight foreword. Remember the pressure that is inside the box when in use so I would think that reusing gaskets or silicon would not work. Clean up the mating surfaces. I had the book and did not find it that handy, but still get it. Also the leather covers for the upper arms and the rubber covers for the lower arms are not in the kit. You will need to secure the covers on the upper arms with wire. Around here the service manager and parts men are pretty helpful.
  • Also VAJerry 18:30:27 04/02/06 (2)
