Re: Farmall 200 Drowning
Posted by Shrps74 on April 03, 2006 at 09:40:13 from (64.12.116.65):
In Reply to: Re: Farmall 200 Drowning posted by Fencemender on April 03, 2006 at 08:07:28:
No, no issues with the governor at all. Sounds like you may have a weak spring in the governor. After you run for a few minutes, go to the carb/governor rod. Leave tractor at idle speed (about 700rpm or so). With your hand move the rod backwards as far as it will go. If the governor is working properly, it will accelerate and then the governor will "force" the carb back to idle speed. If it isn't almost instantaneous, you probably have a weak spring or your carb needs an adjustment (set it at 1 1/4 turns out from lightly seated to start). BobG in VA
