Re: found a hydro 656!
Posted by Nat 2 on April 03, 2006 at 11:47:10 from (64.80.108.52):
In Reply to: Re: found a hydro 656! posted by 26Red on April 03, 2006 at 11:23:06:
Your only real worry is if the hydro is on its way out. A rebuild will easily exceed the cost of the tractor, unless you can fix it on the cheap like Allen did with his. There's no "take it out and send it in," either... You're basically talking about half the rear end of the tractor... a little big for UPS.
You've just got to keep that in mind, is all. If you feel the hydro is in good shape, go for it. If you're afraid the hydro is shot, pass.
