Re: Slow cranking M
Posted by the tractor vet on April 03, 2006 at 18:36:42 from (66.202.111.204):
In Reply to: Slow cranking M posted by MarkCo on April 03, 2006 at 18:19:03:
Even with good starters and good correct cables and a good high amp 6 volt battery if that old M has had high compression pistons and head put on it it will turn slow as did my buddys M that we did over way back many moons ago it turned the engine over like you were hand crankeing it and IF we could ge the fan to make half a turn it would start Like i said IF . And yes going to 12 volt would help and it is not a big deal doing it as there are a couple way that it can be done it is all in the way you want to do it.
