Re: Farmall B restoration
Posted by El Toro on April 04, 2006 at 12:57:01 from (205.188.116.133):
In Reply to: Farmall B restoration posted by bshannon on April 04, 2006 at 11:26:44:
I would use transmission fluid and let it soak. I would pull the head and drop the oil pan too.
If doesn't free up after a week of soaking. I would unbolt the connecting rod cap that is vertical to the engine and use a 2X2 piece of oak
and a big hammer and tap on that rod to see if it will move. Don't pound too hard as you don't want to damage the block. These are wet sleeves and they will sometimes come out with piston inside. Just use a torch to heat the sleeve and your piston will probably slide out. You can probably use the old rods on your new pistons. I did that on a Farmall A. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
