Re: Farmall B restoration
Posted by old on April 04, 2006 at 13:35:07 from (207.69.139.146):
In Reply to: Farmall B restoration posted by bshannon on April 04, 2006 at 11:26:44:
I agree with Hal, tranny fluid and or a mix of tranny fluid and turpentine. If that doesn't work after a week or so you might pull the head and then top that off with a tablespoon of gas and light the gas. Be careful if you do the gas thing and be out side and have a way to put it out if need be. What that does is heats up the block but doesn't heat the rings or piston. The last one I freed up I had to do that and still when it popped loose #2 sleeve came up and out of the block and took my 12 ton press to get it out of the sleeve.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
