Re: 240 Utility gears grind
Posted by Peabody on April 04, 2006 at 20:11:32 from (64.12.116.65):
In Reply to: Re: 240 Utility gears grind posted by Nadz in PA on April 04, 2006 at 16:28:44:
Yes, you have to split it. It's not that big of a deal, as long as you have the right stuff to support the two halves. An engine lift is sufficient for the front end, attached to a chain bolted to the valve cover studs. I used a 55-gallon drum dolly to support the rearend, with necessary wood blocking. Both halves are not that heavy when balanced, just a little cumbersome. If I can do it, you can. My buddy and I had my SC split, replaced the clutch and flywheel ring gear and had it back together in less than two hours.
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
