Re: Slow cranking M
Posted by El Toro on April 05, 2006 at 03:59:01 from (64.12.116.65):
In Reply to: Slow cranking M posted by MarkCo on April 04, 2006 at 17:58:55:
When you get those new cables, welding cables make good battery cables, be sure to clean all terminals including the surface where your battery is grounded. Paint is good insulator. Then check your charging rate across the battery terminals at 3/4 throttle. Hal
