Re:Powerful magnet recharging demag tips
Posted by woodache on April 05, 2006 at 07:35:06 from (207.170.236.38):
In Reply to: magnet recharging posted by F-30 on April 04, 2006 at 20:19:15:
Say you need a magnetic screw driver in the field just wrap the screw driver with insulated wire flash the ends across the battery.
You may need somthing more powerful for the shop, use a old AC motor. Take the ends off the motor remove the rotor take the leads ends flash on battery while haveing the part inside of the old motor.
Now you may need to demag something, intstall a push botton switch in the same old motor, wire in a 110V AC plug put your part to be demaged inside the field, hold the botton/switch a few seconds its done!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
