Re: magnet recharging
Posted by Ed Topel- Instructions on April 05, 2006 at 21:00:06 from (205.188.116.133):
In Reply to: magnet recharging posted by F-30 on April 04, 2006 at 20:19:15:
Use #14 soild core wire
Make about 30 turns on each leg
Observe winding direction
Place keeper bar across ends of magnet (keeper should be cast iron but steel should work)
Touch wire ends to 6 volt battery for 1 to 2 seconds
Slide keeper off both ends of the magnet at the same time
Double check polarity- trademark side should attract the needle of a compass (north
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
