Re: 240 Utility sloppy steering
Posted by TDK on April 05, 2006 at 23:28:28 from (152.163.100.65):
In Reply to: 240 Utility sloppy steering posted by David (Northern MN) on April 03, 2006 at 19:35:16:
The 240 steering is basically the same as the C & S/C boxes. What the guy was speaking of was the gear inside box. It can be turned 180 degrees to eliminate a lot of the play. Front axle has to be removed and the gear assy can be removed from bottom.
