Re: Hy-Trans
Posted by Nebraska Cowman on April 06, 2006 at 04:43:32 from (65.169.97.206):
In Reply to: Hy-Trans posted by Kevin Hood on April 06, 2006 at 04:11:22:
CASE-AKCELA-HY-TRAN-ULTRA
TECHNICAL CHARACTERISTICS
AKCELA HY-TRAN ULTRA
PRODUCT CODE: 1729
APPLICATION
Specific fluid for hydraulic transmission system, final reduction gear, wet brake, for CASEand CASE IH equipment. The only product satisfying CASE MS 1209 specifications.
SPECIFICATIONS
MS 1209
TEST DESCRIPTION
TEST DESCRIPTION METHOD UNIT TYPICAL
VALUES
APPEARANCE B. & C.
SPECIFIC GRAVITY @ 15°C ASTM D 1298 0,880
VISCOSITY @ 100°C ASTM D 445 cSt 6,75
VISCOSITY INDEX ASTM D 2270 105
VISCOSITY @ -20°C ASTM D 2602 cPs 4000
FLASH POINT Cl. O. C. ASTM D 92 °C 200
FOAM @ 24°C ASTM D 892 cc/s 0
RESEARCH & DEVELOPMENT 02/2004
All technical data is provided for reference only.
