Re: 3588 IH,
Posted by the tractor vet on April 06, 2006 at 09:06:39 from (64.179.117.104):
In Reply to: 3588 IH, posted by Kirk in ks, on April 06, 2006 at 07:21:05:
Thats a big job on a 2+2 and will require a double split and about a grad or better in parts and while you where there it would be the time to install a new T/A and clutch and that will be another grad or better plus fixen the center pivot pins so before you are done you will have about 8-9 grad in repairs with labor as this is not one of them tractors that is for the DIY as i needs specil splitting stands and no you can not barrow mine.
