Re: Farmall M........water in oil
Posted by El Toro on April 06, 2006 at 13:29:48 from (152.163.100.65):
In Reply to: Re: Farmall M........water in oil posted by rbuss66 on April 06, 2006 at 11:12:23:
If you see any sign of antifreeze around the lower
block you should pressurize the radiator with 5 or 6 lbs of air pressure. You don't want to rupture the radiator with too much pressure. You then may be able to determine where the leakage is. I would look for any bubbles first. Hal
