Hey BMC-FFA F-14 kerosene
Posted by Farmallgray on April 06, 2006 at 17:37:29 from (205.188.116.133):
You old post was getting pretty far down.
As far as compression, you cant tell from the outside what the compression ratio was, so that doesn't matter. The fuel line does not run through the manifold. The manifold and carb were probably different from the gas version. The kerosene manifold would have an adjustable heat flapper to direct exhaust heat around the intake charge. Your best bet if you want it to be 100% correct, would be to get a parts book and study the different parts from kero to the gas version.
Hope this helps.
