Re: Loader capacity
Posted by FromJB2 on April 06, 2006 at 17:59:31 from (72.56.121.128):
In Reply to: Loader capacity posted by johann on April 06, 2006 at 17:37:44:
Hi Johann, if it is 1 cubic yard of concrete then I don't think a 2001 loader will lift it as that is over 3800 lbs. About 2500 lbs would be max lift. Most loaders of that era had a lift capacity of 2000 to 2500 lbs.
See for concrete weight:
http://books.google.ca/books?ie=UTF-8&vid=ISBN0486409309&id=TiwiGsfo5i4C&pg=SA3-PA9&lpg=SA3-PA9&dq=weight+of+cubic+yard+of+concrete&sig=aUAxDaSWoKSMdyqopuOHPCYwFBk
BE VERY CAREFUL 3800 lbs is a big load.
JB2
