Re: Farmall M........water in oil
Posted by mbnok on April 06, 2006 at 20:11:54 from (216.226.31.39):
In Reply to: Farmall M........water in oil posted by rbuss66 on April 06, 2006 at 09:08:42:
I'm now working on my H. It had antifreeze in the oil. I pulled the pan and put a piece of white cardboard under it, after awhile nothing showed up. I got out my little flash light bulb I soldered onto some fine wires and stuck it in the sparkplug holes
nothing I could see that looked unusual, so I pressured up each cylinder, no bubbles, well I finally started taking it apart and saw a odd looking puddle on top of the head it had antifreeze in it, under that was a hairline crack I guess it would only let antefreeze thru. but anyway way a weld job and a new valve job and maybe, some ambition, I will find out if I've fixed it.
I hope there are some ideas in this that might be helpfull.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
