Re: M carb problem
Posted by RustyFarmall on April 07, 2006 at 06:37:44 from (207.32.13.220):
In Reply to: Re: M carb problem posted by chadd on April 07, 2006 at 05:26:48:
Chadd, I think you are correct. I've never seen an IH combine that had a carburetor which would interchange with an M, because, as you said, there is no provision for a governor connection on the combine carb. I suppose it may be possible that the bowl portion of the combine carb might interchange with the M, but I am not sure of that.
