Posted by gene bender on March 11, 2009 at 04:05:47 from (67.55.226.145):
In Reply to: throttel speed posted by Jimmy Neal on March 10, 2009 at 19:09:55:
Sounds like the gov spring is broke and you have to remove the housing to replaceit. If the input lever has a lot of wobble it should be rebushed. When you have the gov housing off check all springs to make sure they are free . You need to be careful not to lose the sleeve and three pc thrust bearing. Also the spring loaded pin on the end of the shaft.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
