Re: Super C icing-up
Posted by captaink on April 07, 2006 at 14:05:05 from (66.115.214.56):
In Reply to: Super C icing-up posted by Trickster on April 07, 2006 at 13:34:43:
This is totally normal. It is caused by the venturi effect which is that when air passes through a space that is smaller in diameter (like the venturi of a carburetor), the air flow speeds up and absorbs heat from the surrounding surface. This removal of heat (or cooling) will condense moisture in the surrounding air on the cooler surface. If the temps are close enough to freezing, ice will form not only outside but also on the inside. This cooling affects the air/fuel mixture causing the engine to run rich until heat from the exhaust manifold overcomes the cooling venturi effect. Now, is this what is causing your engine to stop after 20 minutes or so? Well, it might as this condition can richen the fuel mixture enough to flood the engine bad enough to cause it to stall. If you are seeing black smoke from the exhaust before it dies, then this is likely the cause. The cure is to run the engine faster or somehow get heat to the area that is freezing up. Sometimes gas line antifreeze (or running ethanol) will absorb enough of the moisture inside the carburetor to cut down on this problem.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
