Re: Super C Stalls under load when warm. Won't res
Posted by BobG in VA on April 07, 2006 at 14:28:38 from (205.188.116.133):
In Reply to: Super C Stalls under load when warm. Won't restart posted by Josh Blauvelt on April 07, 2006 at 08:53:22:
Been there, done that. If you need a rebuild, you also should soak the carb in carb cleaner (gallon bucket) once you have it apart. After about 4 hours in the cleaner, take it out, rinse it well with HOT SOAPY water, then rinse it again. Once this is done, pump up your compressor to about 100PSI and blow out all the little passageways, including the gas inlet on the side of the carb. You will be surprised how well your tractor will run after this even if you don't put a kit in it, but take it apart (get a new gasket) and do the forgoing. BobG in VA
