Re: Crank bearing caps
Posted by ChadS on April 09, 2006 at 05:29:18 from (66.228.96.242):
In Reply to: Crank bearing caps posted by John London, Tx on April 09, 2006 at 05:08:42:
Best to use the caps that was on the block. The block needs to have the mains aligned bored. One bore, or more is out of measurement. I found a M block that was like that, The center main was .010 tighter than the front and rear bores. Its worth the time and $$. JMHO, Chad
