Re: 444 Brakes
Posted by FromJB2 on April 09, 2006 at 07:38:10 from (72.56.121.128):
In Reply to: 444 Brakes posted by Weav on April 09, 2006 at 06:43:38:
Hi Weav, the 444 has disk brakes in a housing behind your left and right heel while sitting on the tractor. The setup is an inner and outer doubled sided disk with a mechanism in the center that is activated by the brake pedal. The braking mechanism is 2 metal surfaces with 3 metal balls between that run in a ramped channel. As you apply the brakes the balls are supposed to roll up the ramp spreading the 2 metal surfaces apart applying pressure to the 2 disk brake rotors. Problesms: 1)Disk brake crud gets in the roller ball channel. Solution disassemble, clean crud out and apply VERY LIGHT coat of white grease on balls and channel. 2)Disk brake rotors become glazed and shiny. Solution disassemble, remove glaze with wire brush or edge of metal file. Try to keep surface even. 3)Someone has replaced disk brake rotors with new ones and these new rotors are riding up on the edges of the worn metal surfaces. Solution disassemble, take a file or rask and file away the outer edges of the disk brake rotor so that it will fit against the worn metal braking surfaces. Time required to repair is about 1 hour per brake. Disassembly instructions: 1)Park tractor on level surface, shut off leave in 2nd gear LO, block rear wheels. 2)Remove brake pedal adjusting bolt and rubber boot. 3)Remove 4 bolts from disk brake housing and pull housing away from transmission and eveything should be exposed. On the right side you may have to remove parking brake mount to have clearance to remove brake housing. Good luck JB2
Home
| Forums
Today's Featured Article -
On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
