Re: Taking a part U-joint
Posted by Bob on April 09, 2006 at 10:45:14 from (64.21.249.40):
In Reply to: Taking a part U-joint posted by Jimer on April 09, 2006 at 10:19:51:
Try some penetrating oil, and carefully grip the protruding cup with a slip joint pliers or ViseGrip. Hopefully, you can twist and pull it out.
Just be carefull not to bend the "ears" on the yoke when you are pressing on the cups, or it will be impossible to get the snap rings back in when you reassemble the joint and/or it will bind.
