Re: H carb ajustment
Posted by CNKS on April 09, 2006 at 13:33:51 from (204.249.178.138):
In Reply to: H carb ajustment posted by outlaw2413 on April 09, 2006 at 10:38:10:
I would set it "by the book" first to get a starting point -- it may well be ok if you set it this way first. With the engine at operating temperature and wide open throttle, turn the main jet adjusting screw in until the rpm begins to drop, turn it out until smooth and add about a quarter turn. You should also adjust the idle at the same time. First set the idle speed (speed not mixture) with the throttle closed, just fast enough so that the engine runs smooth. Then adjust the idle mixture the same way you did the main jet. The only difference is that when you turn the idle in you are richening the mixture, turning the main screw in leans the mixture. But, the idle is adjusted the same way -- you find the spot where it runs smooth. You may have to do the idle and the main jet a couple of times each. RPM should pick up smoothly without stumbling as you move the throttle rapidly from the closed to the open position. Then you can richen the mixture a quarter turn at a time if it stumbles under load. But, with a new, properly adjusted carb, you should not need to adjust it very much at all. If you still have a problem, it is probably not carb related.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
