Re: Farmall H Temp gauge...Problems
Posted by jeffalex2 on April 09, 2006 at 18:44:33 from (151.196.171.13):
In Reply to: Farmall H Temp gauge...Problems posted by Ryan in PA on April 09, 2006 at 18:20:34:
Those old gauge types don't use electric. They work off of heat transfer thru the core of the braided transfer cable. The gauge could be stuck/defective. If you pull the sending unit back out and pass a propane torch or lighter back and forth across it, you should see the gauge rise.
