Re: 966 ta and clutch
Posted by Bob on April 09, 2006 at 19:15:40 from (64.21.249.40):
In Reply to: 966 ta and clutch posted by Glen H on April 09, 2006 at 19:02:01:
There are several TA and clutch choices available from Mother CNH, as well as aftermarket suppliers like HiCapacity and others.
MCV = Multiple Control Valve = the plate stack on the LH side of the tractor, behind the clutch housing that the steering lines, the TA shift lever, as well as the clutch dump valve rod all connect to. The power steering pump is internal, mounted to the backside of the MCV.
